07-17-2007 02:02 PM
07-18-2007 08:25 PM
Hi Kevin,
Internally routing the sample clock to the DIO channels is not possible using
your 6534. Perhaps if you told me a little bit more about your application I
might be able to come up with some way to help.
07-19-2007 12:42 PM
07-19-2007 05:21 PM
07-20-2007 04:35 PM
Hi Kevin,
Using the setup that you described, you will be limited to outputting half of
the frequency of the clock signal. If you route through the counter you will
have to divide down the source and if you route through the digital output, you
will only be able to toggle the output up and down on every other clock edge thus
dividing your frequency in half again.
07-26-2007 12:39 PM
07-26-2007 12:49 PM - edited 07-26-2007 12:49 PM
Sorry, that pic didn't work.Message Edited by digitalIO on 07-26-2007 12:50 PM
07-26-2007 02:09 PM
10-22-2007 04:55 AM
10-23-2007 11:36 AM - edited 10-23-2007 11:36 AM
Message Edited by Jordan D on 10-23-2007 11:36 AM
