Digital I/O
SCXI Module for Cable Position Transducer
I am in the market for a position transducer.  BEI industrial encoders sells a position transducer that outputs a digital signal.  http://www.beiied.com/PDFs2/Linear-Cable_Transducer_LT25.pdf
Any recommendations on an SCXI module that would allow me to acquire the signal from this transducer?
An example output waveform is shown below as well as the electrical specs.
(3,348 Views)
Hi j3B,
     I think the problem you're going to have trying to do this is the fact that SCXI modules don't have counters.  A better option would be to pursue a different form factor, either a counter time card, or you may want to consider the suggestions made in this document.  Have a great day!
(3,327 Views)
