Digital I/O
SDRAM load capacitance calculator
I am interfacing SDRAM IS45S32160F-7BLA2 with MPC8270 PowerPC Processor.
Input capacitance of SDRAM is 6pF per data line and i am using 4 SDRAM's which add upto 24pF of capacitance load.
Processor suggest to have a minimum loading of 20pF.
Now the problem is current . Processor datasheet says Ioh = -2mA and Iol = 6mA. at Voh = 2.4 and Vol = 0.4
Keeping this current in mind, i=C dV/dT fails, as 20pF of load capacitance needs around 60mA and Iol and Ioh is 2 to 6mA ,
So how this 6mA will fullfill the requirement of 60mA of load. This load is on databus of processor.
(2,678 Views)
The current listed is for steady state in the VoL or VoH condition.  The external capacitance is there for damping the ringing during transitions.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(2,649 Views)
Ok , so is the input capacitance valid even when the CS (Chip select) of a particular bank is disabled.
I am using 4 SDRAM on 4 banks, but only 1 is active at a time so does i have to calculate input capacitance of 1 SDRAM at a time or 4 SDRAMs?
(2,637 Views)
