Digital I/O
SPI Read/write PXIe-6537
Hello
I'm looking into the possibility of implementing SPI write/read data with an NI PXIE-6537 board.
I wanted to test the example: SPI Generation and Acquisition using HSDIO Hardware (654x)
but I still have problem with SDW.lvlib library.
Can you confirm the possibility of implementing an SPI bus with the PXIe-6537 card?
Do you have examples of code (Labview or other) allowing a send/receive bytes in SPI?
Thanks in advance.
(1,591 Views)
Hello fishingman,
According to the specifications of NI PXIe-6537, it seems not compatible with SPI communication. The example you try to use is for the NI PXIe-654x series which are Digital Waveform Generators and Analyzers and can handle the SPI communication as there is enabled clock sharing, but the PXIe-6537 is a Digital I/O module.
Hope this was helpful.
Best Regards
(1,558 Views)
