Digital I/O
Sampling 500kHz 8 digital input with USB-6341/6343
I'm looking for a device that can be connected with an FPGA to sample 8 digital input at positive edge of an external clock running at 500kHz.
My question is, will USB-6341 or 6343 be capable of doing this?
Also, could I use MatLab to control this interface rather than LabView?
Thank you,
Kris
(5,010 Views)
Hello Kris,
I’m not sure what you mean when saying the device must be connected with an FPGA. Is this an NI device with a built in FPGA you are connecting to? Without knowing more information, it’s difficult to understand the context of your application and make recommendations.
That being said: To accurately measure the frequency of a digital pulse train, you will need to sample at a frequency greater than 2x the signal frequency for a 50% duty cycle. By sampling faster, you can more accurately detect rising/falling edges and measure frequency/pulse width.
For the best results, we recommend doing edge detection using a counter with counter tasks. Counters have access to reference clocks up to 80Mhz in general, and are hence more accurate and more responsive to the pulse train then a DI/O line will be. However, USB DAQ devices do not possess eight counters.
I recommend contacting our product advisors we can obtain a better understanding of your application, determine the performance you require, and recommend a suitable device. They can be reached throught the appropriate links here:
http://www.ni.com/advisor/
(4,988 Views)
