Digital I/O
Using DIOx line on NI-8452 as SPI_DATA (SPI_MOSI)
Newbie to labview.  Would like to know if one of DIO lines on the NI-8452 can be configured as SPI_DATA  (SPI_MOSI).   Synchronizing it with the SPI_CLK.
I’m using SPI_CLK as the RCLK for 74hc595.   DIO1 as SER data input to 74hc595.  DIO2 as RCLK  for 74hc595.
Thanks.
kvn
(5,363 Views)
Hey kvn,
Unfortunately, the DIO on the 8452 are all software-timed, so there isn't a way to tie their output to a hardware clock like SPI_CLK. They are really intended to be used as basic DIO lines for evaluating external conditions that may need to influence the execution of your application, rather than as hardware-timed input or output.
If you would like to read all of the capabilities for yourself, check out the NI-845x Hardware and Software Manual.
I hope this helps.
Ryan
Ryan P.
CLA
(5,352 Views)
