Digital I/O
Saving data from daq at iterations
I am doing some testing on some materials. my setup cycles a relay to change a solenoid valve and im monitoring the pressure over time with a pressure sensor. Id like to save this data say every 5 min so im not constantly processing and saving. I dont know what the best approach is or what will work best.
Im trying write to measurement file but cant get it to work the way id like it to. any help is appreciated
to use this vi you will need the drivers/libraries for my relay and daq, which are too large to load so I have attached links. otherwise another vi just simulating a signal could carry out the same function
http://www.phidgets.com/docs/Language_-_LabVIEW#Quick_Downloads
http://www.mccdaq.com/daq-software/universal-library-extensions-lv.aspx
(4,514 Views)
Accepted by topic author cgarlow
Hi cgarlow,
Have you tried using the "flush?" input on the Write To Measurement File Express VI?  This input allows you to specify when LabVIEW writes data to a measurement file.
(4,483 Views)
Thanks for your help, this ended up working, there is an example showing how to save after x number of iterations with the flush input. I ended up having to save locally, having it save to my server caused too much bogging down
(4,443 Views)
