Digital I/O
pressure transducer question
Hi guys, does any of you have seen this kind of pressure transducer? (See the attachment)
Mine was broken because one of the leads were completely fell off. So, I need to find a new one, but I can't find the part number.
P.S All I can read on the transducer are some random words and numbers. Here is what I see if I place the opening toward the front.
On the left side: 6ff8g; 201020n. On the back: Micro. On the right, blank.
THANK YOU GUYS!!!!!!
(5,151 Views)
Is it a NI product?
(5,133 Views)
I guess so.
(5,127 Views)
NI does not make transducers. No one ever created a BOM? What about purchase order records? What sort of test are you doing? From the requirements, you should be able to find a replacement.
(5,114 Views)
See those markings on the side? Try punching those into your search engine of choice.
(5,086 Views)
You should also look for someone to solder the leads properly. The solder points look awful.
(5,068 Views)
Never seen transducers made by NI.
(4,957 Views)
