10-15-2015 08:33 PM
Hello guys,
I'm new to DAQmx base and have some doubts.
First of all I'm running Scientific Linux 6.7, DAQmx base 14.0, Eclipe IDE and USB-6009 device.
Device communication is ok and my program is copiling and running.
My program has two tasks, each one with a DO channel.
The problem is that when a write data to the DO channel of one task the DO channel of the other task is also being affected.
Fernando
Follows my code:
#include <NIDAQmxBase.h>
#include <stdio.h>
#include <termios.h>
#include <unistd.h>
#include <fcntl.h>
#define DAQmxErrChk(functionCall) { if( DAQmxFailed(error=(functionCall)) ) { goto Error; } }
int main (int argc, char *argv[])
// Task parameters
int32 error = 0;
TaskHandle DO_task = 0;
TaskHandle DO_data_task = 0;
char errBuff[2048];
// Channel parameters
const char DO_led[] = "Dev1/port0/line2";
const char DO_data[] = "Dev1/port0/line1";
// Read parameters
uInt32 data [1];
int32 byte_conter;
// Create Digital Input (DO) Task and Channel
DAQmxErrChk (DAQmxBaseCreateTask ("", &DO_task));
DAQmxErrChk (DAQmxBaseCreateDOChan(DO_task,DO_led,"",DAQmx_Val_ChanForAllLines));
// Start Task (configure port)
DAQmxErrChk (DAQmxBaseStartTask (DO_task));
DAQmxErrChk (DAQmxBaseCreateTask ("", &DO_data_task));
DAQmxErrChk (DAQmxBaseCreateDOChan(DO_data_task,DO_data,"",DAQmx_Val_ChanForAllLines));
DAQmxErrChk (DAQmxBaseStartTask (DO_data_task));
// write to port
data[0]=0xFF;
//DAQmxErrChk (DAQmxBaseWriteDigitalU32(DO_data_task,1,1,10.0,DAQmx_Val_GroupByChannel,data,& byte_conter,NULL));
DAQmxErrChk(DAQmxBaseWriteDigitalScalarU32 (DO_data_task, 1, 10.0, 0xFFFF, NULL));
// write to port
data[0]=0x0;
//DAQmxErrChk (DAQmxBaseWriteDigitalU32(DO_task,1,1,10.0,DAQmx_Val_GroupByChannel,data,&byte_ conter,NULL));
DAQmxErrChk(DAQmxBaseWriteDigitalScalarU32 (DO_task, 1, 10.0, 0x0000, NULL));
Error:
if (DAQmxFailed (error))
DAQmxBaseGetExtendedErrorInfo (errBuff, 2048);
if (DI_task != 0)
DAQmxBaseStopTask (DI_task);
DAQmxBaseClearTask (DI_task);
if (error)
printf ("DAQmxBase Error %ld: %s\n", error, errBuff);
return 0;
10-16-2015 10:15 AM - edited 10-16-2015 10:15 AM
I would suggest you learn the difference between DAQmx_Val
