Digital I/O
usb-6009
Hello guys,
I'm new to DAQmx base and have some doubts.
First of all I'm running Scientific Linux 6.7, DAQmx base 14.0, Eclipe IDE and USB-6009 device.
Device communication is ok and my program is copiling and running.
My program has two tasks, each one with a DO channel.
The problem is that when a write data to the DO channel of one task the DO channel of the other task is also being affected.
Fernando
Follows my code:
#include <NIDAQmxBase.h>
#include <stdio.h>
#include <termios.h>
#include <unistd.h>
#include <fcntl.h>
#define DAQmxErrChk(functionCall) { if( DAQmxFailed(error=(functionCall)) ) { goto Error; } }
int main (int argc, char *argv[])
   // Task parameters
   int32       error = 0;
   TaskHandle  DO_task = 0;
   TaskHandle  DO_data_task = 0;
   char        errBuff[2048];
   // Channel parameters
   const char  DO_led[] = "Dev1/port0/line2";
   const char  DO_data[] = "Dev1/port0/line1";
   // Read parameters
   uInt32      data [1];
   int32       byte_conter;
   // Create Digital Input (DO) Task and Channel
   DAQmxErrChk (DAQmxBaseCreateTask ("", &DO_task));
   DAQmxErrChk (DAQmxBaseCreateDOChan(DO_task,DO_led,"",DAQmx_Val_ChanForAllLines));
   // Start Task (configure port)
   DAQmxErrChk (DAQmxBaseStartTask (DO_task));
   DAQmxErrChk (DAQmxBaseCreateTask ("", &DO_data_task));
   DAQmxErrChk (DAQmxBaseCreateDOChan(DO_data_task,DO_data,"",DAQmx_Val_ChanForAllLines));
   DAQmxErrChk (DAQmxBaseStartTask (DO_data_task));
   // write to port
   data[0]=0xFF;
   //DAQmxErrChk (DAQmxBaseWriteDigitalU32(DO_data_task,1,1,10.0,DAQmx_Val_GroupByChannel,data,& byte_conter,NULL));
   DAQmxErrChk(DAQmxBaseWriteDigitalScalarU32 (DO_data_task, 1, 10.0, 0xFFFF, NULL));
   // write to port
   data[0]=0x0;
   //DAQmxErrChk (DAQmxBaseWriteDigitalU32(DO_task,1,1,10.0,DAQmx_Val_GroupByChannel,data,&byte_ conter,NULL));
   DAQmxErrChk(DAQmxBaseWriteDigitalScalarU32 (DO_task, 1, 10.0, 0x0000, NULL));
Error:
   if (DAQmxFailed (error))
      DAQmxBaseGetExtendedErrorInfo (errBuff, 2048);
   if (DI_task != 0)
      DAQmxBaseStopTask (DI_task);
      DAQmxBaseClearTask (DI_task);
   if (error)
      printf ("DAQmxBase Error %ld: %s\n", error, errBuff);
   return 0;
(4,320 Views)
I would suggest you learn the difference between DAQmx_Val_ChanForAllLines and DAQmx_Val_ChanPerLine
(4,300 Views)
