Digital I/O
Stacked Sequence Structure
I've used Stacked Sequence Structure to create some digital control signal,but the signal's output frequency is too low to work properly,I want to known how can I boost the output frequency. The hardware I use is DAQCard-6062E! Thanks very much!Smiley Indifferent
(3,308 Views)
Hello Lao Wan,
I see that you are using the DAQCard-6062E and would like to output a digital signal. What programming environment are you using? Are you using LabVIEW? What driver are you using, Traditional DAQ or DAQmx? What sort of digital signal are you outputing? digital pulse train?
I need more information about your application.
  Sandra T.
Applications Engineer | National Instruments
(3,284 Views)
