Digital I/O
Standalone SW for USB-6509
Are there any SW running standalone and which may communicate with the USB-6509 DIO module?
In the end our SW developers will use Labview/Teststand but in a bring up periode it is preferred to use something lightweight "install and run" sw if available. I found a few similar topics talking about an excel VBS plugin but the links they provided where broken and old.
(1,460 Views)
When you install DAQmx, you should also be installing Measurement and Automation Explorer (MAX).  In MAX, find your device under "Devices and Interfaces" and then in the panel you can choose to open a test panel.
GCentral
(1,445 Views)
