06-15-2023 09:25 PM
Hi
06-16-2023 08:00 AM
I would probably go with a small PXI system. There are plenty of DIO cards and AO cards you can use. You would need separate cards to handle your RS-232 and RS-422.
06-16-2023 08:15 AM
For a lower cost option, you could consider cDAQ and C Series modules as well.
06-17-2023 01:40 AM
Can you suggest some cards with part number. The functionality I want to embed is that I can give inputs from the tester card to my board and read response from my custom card on the tester as well.. Does this application requires a card with a FPGA??
06-17-2023 01:45 AM
Dont u think PXI Chasis with cards is a costly solution??
If there is a card which can output isolated Digital signals of LVTTL on general purpose header pins and analog chanels with seperate grounds it will serve the purpose.
Is there any NI card with such functionality which can be inserted in FMC slot of the base card???
06-17-2023
10:54 AM
- last edited on
09-04-2025
06:09 PM
by
Content Cleaner
It depends on how fast you want the response to be. if you just want to do a write-and-read test, cDAQ might do the work. If you need to do some fast control, you might want to use the FPGA.
Depending on the input and output range, you can make your choice.
