Digital I/O
Suggest hardware for a custom DAQ card
Hi
  • I have a customised DAQ board with artix7 FPGA with acquisition for 32 analog channels, 64 digital channels and serials (422 and 232). Before handing over to the end user I have to test each analog and digital channel manually for the proper functionality of the board. Digital channels are isolated through a buffer. Analog ADC(7616) grounds are seperate as well.
  • Now I want to design a tester for that board to automate the testing procedure. Manually checking of every channel is hectic.
  • I want help regarding the appropriate DAQ cards which fullfill the requirements. I have googled the catalog but unable to find. I wish some SbRIO card fullfill that but 😂
(1,894 Views)
I would probably go with a small PXI system.  There are plenty of DIO cards and AO cards you can use.  You would need separate cards to handle your RS-232 and RS-422.
GCentral
(1,856 Views)
For a lower cost option, you could consider cDAQ and C Series modules as well.
https://tmesystems.net/
(1,850 Views)
Can you suggest some cards with part number. The functionality I want to embed is that I can give inputs from the tester card to my board and read response from my custom card on the tester as well.. Does this application requires a card with a FPGA??
(1,820 Views)
Dont u think PXI Chasis with cards is a costly solution??
If there is a card which can output isolated Digital signals of LVTTL on general purpose header pins and analog chanels with seperate grounds it will serve the purpose.
Is there any NI card with such functionality which can be inserted in FMC slot of the base card???
(1,819 Views)
It depends on how fast you want the response to be. if you just want to do a write-and-read test, cDAQ might do the work. If you need to do some fast control, you might want to use the FPGA.
Depending on the input and output range, you can make your choice.
(1,793 Views)
