Hi! I'm bit confused... I want use USB 6008 device to output digital control signals for 595 registers (data, Clock, latch and output enable). I've found some examples for digital output generation and tryed to apply it for task. Output is suprise for me - sometimes signal shape changes (misses some pulses) whithout any obvius (for me) reason. Data to write out is the same, i just run vi few times and expect output to be something like this:
but sometimes i get this:
Theese images i got with the same 6008 - using analog inputs attached to digital outputs.
Here's one vi:
Second VI i'm usig, uses analog to digital wavefrom conversion and DAQ mx, but there's some missing pulses too.
Can someone point me where's the problem, why i get some missing pulses?
p.s. sometimes it's not missing pulses, but pulse width changin...
Message Edited by Pufaix on 03-19-2007 04:05 AM
