Digital I/O
USB-6525 - How to write/read a line using functions
a) what functions in NIDaqMx do i have to call to set/read a specific line (0..7)?
DAQmxClearTask(TaskHandle)
DAQmxCreateTask(TaskName, TaskHandle)
DAQmxResetDevice(DeviceName)
DAQmxCreateDOChan(g_TaskHandle, Lines, NameToAssignToLines, LineGrouping)
DAQmxStartTask(g_TaskHandle)
DAQmxStopTask(g_dwTaskHandle)
b) What happens to the line state if a line was set to true and then the Task is stopped. Does this also set the bit back to default state?
BR
(1,391 Views)
Hi OnlyOne
I don't understand what you mean by saying 'line'. Did you mean string data type or something different?
In any case the answer for the first question will be this,
a) You should use DAQmxReadTask VI to read data from specified physical channel.
Regards)
(1,244 Views)
Accepted by OnlyOne
"line" means one bit. A typical port has 8 lines.
Meanwhile i solved it by myself.
(1,238 Views)
