Digital I/O
USB 8451 - SPI Communication with 4 IC's - C++
I am about to use Melexis 90316 IC's: 4 of them. I am communicating using the SPI framework with the USB 8451. Figure 17.4.2 of the datasheet I have attached essentially shows how I would connect the chips. Here's the problem: I am looking to acquire all the data at the same time, but the 8451 only has one MOSI and one MISO port. Is there a way to setup the DIO channels on the other side of the device to acquire the MISO data continuously and in parallel from all 4 chips? Additionally: I have just begun to familiarize myself with the C++ API: do I have to run everything as a script to make things go faster? How does one do continuous streaming of input data without constantly having to query each IC?
Thanks for your help!
Nathan
Message Edited by ElectricNathan on 07-13-2007 12:55 PM
(3,560 Views)
Duplicate post.  Please refer to this post for discusion about this topic.
Jason W
(3,533 Views)
