Digital I/O
outputing five digital waveform from NI9401 in contin. mode
With regard to this post http://forums.ni.com/ni/board/message?board.id=70&message.id=7013  the pulse train I required is the same as the picture in the same post. http://forums.ni.com/attachments/ni/70/7019/1/sequence.JPG
Can I get the 5 output at the same time? and can I use the same examples provided in the post to generate the pulse train in continues mode using the NI 9401?
Also I need to know the range of (time) which I can produce a 100 periods of the 1st pattern (0101…etc). Suppose I want to produce 100 periods each of 2us (rise time 1us and fall time 1us) total of 200us. If not what is the min and max time I can get for such periods using this card.
(3,641 Views)
Hi AbuMohamed,
What carrier are you using with the 9401? Are you using this in a compactDAQ or compactRIO?
Please let me know because this will affect the answer.
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(3,631 Views)
compactDAQ
(3,623 Views)
