Digital I/O
USB DAQ 6001 Resolution
In USB DAQ 6001, when collected data using analog input, 14 mV signal is coming without any actual input.
(1,134 Views)
The USB-6001 is a low-cost, multifunction DAQ device. It offers analogue I/O, digital I/O, and a 32-bit counter. The USB-6001 provides basic functionality for applications such as simple data logging, portable measurements, and academic lab experiments.
(1,117 Views)
  1. For any data acquisition device, inputs should not be left floating as the charge could build up due to the high input impedance (no worries if you will not be reading the signal)
  2. Short the analog input to AGND and see if you observe the same
  3. Please note that the typical accuracy is 6mV and worst case is 26mV
Santhosh
Soliton Technologies
(1,110 Views)
