Digital I/O
Using NI 9401 with cDAQ9174 for RPM Measurements: How to Output 5V for Power While Acquiring RPM
I'm new to LabView and how to use these modules. I want to use a digital hall effect sensor to measure the RPM of a rotating shaft.
How do I output a continuous 5 volts from NI 9401 to power the sensor, while also acquiring the measurement?
Steps I need to take:
1) Generate 5V signal on output line to power the sensor (sensor can be powered from 3V to 28V).
2) Acquire digital signal from sensor on a separate line on the module.
3) Convert digital signal to frequency.
I've tried working through DAQAssistant to generate an output signal. All it gives me when I set up a Digital Line Output is a checkbox to Invert Line. I set the Generation Mode to Continuous Samples, and that is all I changed. Where do I go from here? Once I get the 5V power to the sensor, do I need a separate while loop for the input line or can everything be in one loop?
Thanks in advance!
(3,675 Views)
Have you tried to run the LabVIEW examples? Some of them are related to the steps you need to complete.  Go to help>Find Examples and search for these examples:
1- Voltage (with events) - Continuous Input
2- Thermocouple Continuous Input.vi
For the digital signal check this tutorial:
3- https://www.ni.com/en/support/documentation/supplemental/21/frequency-measurements-how-to-guide.html
I hope that helps.
Mario
(3,649 Views)
The first two examples use analog signals. I have the NI 9401 which is a Digitial I/O module. I've looked into some digital output examples as well but none that can force a specific voltage. If it can't be done, I'll connect the sensor to a 5V battery. I was just hoping to connect it to the module to keep the hardware setup clean.
I haven't gotten to acquiring the signal yet but that tutorial seems helpful!
(3,640 Views)
What port do you have the 9401 Module located in on the 9174?
(3,553 Views)
