08-02-2018 06:02 PM
I'm new to LabView and how to use these modules. I want to use a digital hall effect sensor to measure the RPM of a rotating shaft.
How do I output a continuous 5 volts from NI 9401 to power the sensor, while also acquiring the measurement?
Steps I need to take:
1) Generate 5V signal on output line to power the sensor (sensor can be powered from 3V to 28V).
2) Acquire digital signal from sensor on a separate line on the module.
3) Convert digital signal to frequency.
I've tried working through DAQAssistant to generate an output signal. All it gives me when I set up a Digital Line Output is a checkbox to Invert Line. I set the Generation Mode to Continuous Samples, and that is all I changed. Where do I go from here? Once I get the 5V power to the sensor, do I need a separate while loop for the input line or can everything be in one loop?
Thanks in advance!
		08-03-2018
		01:47 PM
 - last edited on
		01-08-2024
		02:58 PM
 by
			migration-bot
Have you tried to run the LabVIEW examples? Some of them are related to the steps you need to complete. Go to help>Find Examples and search for these examples:
1- Voltage (with events) - Continuous Input
2- Thermocouple Continuous Input.vi
For the digital signal check this tutorial:
3- https://www.ni.com/en/support/documentation/supplemental/21/frequency-measurements-how-to-guide.html
I hope that helps.
Mario
08-03-2018 02:31 PM
The first two examples use analog signals. I have the NI 9401 which is a Digitial I/O module. I've looked into some digital output examples as well but none that can force a specific voltage. If it can't be done, I'll connect the sensor to a 5V battery. I was just hoping to connect it to the module to keep the hardware setup clean.
I haven't gotten to acquiring the signal yet but that tutorial seems helpful!
08-29-2018 12:46 PM
What port do you have the 9401 Module located in on the 9174?
