Digital I/O
What is the wetting current on PXI-2569
As the title says,  I cannot find the spec for wetting current on that relay card. I want to use it to switch some low uA to high mA signals and was wondering what the spec was.
(3,469 Views)
Hi errorTestMan,
This specification is not available through National Instruments.  NI does not actually manufacture the switches for the PXI-2569 device; another company, Tyco Electronics, does the manufacturing for these.  The part information for the switches on that device is located in the Switches Help under the Relay Replacement section for the PXI-2569.
NI PXI-2569 Relay Replacement
The NI PXI-2569 uses electromechanical armature relays.
Refer to the following table for information about ordering replacement relays.
Relay Manufacturer
Part Number
AXICOM (Tyco Electronics)
IM42GR (3-1462037-1)
You may be able to find more information through Tyco’s website and support.
http://www.tycoelectronics.com/
Hope this helps!
Ed W.
(3,443 Views)
