Digital I/O
Writing values to multiple ports on PIC-DIO-96 with DAQmxBase
I am trying to write a program that writes multiple values to different ports on the PCI-6508 (PCI-DIO-96) board using NI-DAQmx Base in C on Mac OS X.
I would like to write values to 3 different ports in sequence. Originally my code would create 3 tasks (one for each port) and then call the DAQmxBaseWriteDigitalOutputU8 function for each task to write the different values to the three ports.
Is there a way to lump the 3 ports into one task and then write an array of values to each port? I have tried to run the writeDigMultiplePorts.c example program, but I get error message -200559. Is this a limitation of the board?
(4,163 Views)
DPBiss,
Thanks for contacting National Instruments.  You can specify multiple ports on the same card, Dev1/port0,Dev1/port1,Dev1/port2 when you configure your task and then write an array to to the task using the same write function you specify.  Be sure to look in the C reference help that can be accessed through the start menu under National Instruments >> NI-DAQmxBase.
Message Edited by Kenn N on 11-10-2006 10:53 AM
Kenn North
Principal Product Manager - Search, Digital Analytics
http://ni.com/search
(4,154 Views)
Ken, thanks for the response, but I still seem to be having problems. I should have done this in my first post, but I'll walk through what I am doing.
I initalize my task like this:
TaskHandle myTask;
char chan[] = "Dev1/port0, Dev1/port1, Dev1/port2";
DAQmxBaseCreateTask("", &myTask);
DAQmxBaseCreateDOChan(myTask, chan, "", DAQmx_Val_ChanForAllLines);
Then I generate the data I want to output to the digital ports, lets just say I want to write 5 values to each port. In this example I want port 0 to get 0, 3, 6, 9, 12, port 1 to get 1, 4, 7, 10, 13, and port 2 to get 2, 5, 8, 11, 14.
uInt8 dataOut[15];
for ( ii = 0; ii < 15; ii++ ) {
    dataOut[ii] = ii;
DAQmxBaseWriteDigitalU8(myTask, 5, 1, 10.0, DAQmx_Val_GroupByScanNumber, dataOut, NULL, NULL);
So this code should write the 5 values in sequence to each of the three ports, correct? I keep getting an error message that says, "Write cannot be performed, because the data does not contain data for all the channels in the task." I don't understand what this means. I tried turning the autostart off and using DAQmxBaseStartTask, but that doesn't help either.
(4,144 Views)
DPBiss,
This code is not going to write the values consecutively.  There is no loop to iterate through.  Try writing a value that is 24 bits wide or a uInt8 array with three elements in it.  The ports on the PCI-DIO-96 are 8-bits wide so you can write 24-bits of data to the ports.  If you want to consecutively write to the port different values you need to setup a loop to write the new values to the ports.
Kenn North
(4,134 Views)
I am currently looping through a bunch of values and calling the DAQmxBaseWriteDigitalU8 function in the loop to write to a channel. I was hoping there might be a faster way to just send a waveform or something and call the DAQmx function once.
Thanks for your help!
(4,122 Views)
DPBiss,
DAQmxBase only has the 3 digital write functions.  None of them can write a waveform to onboard memory.  This is a feature that is implemented in our High-Speed Digital I/O (HSDIO) driver and HSDIO cards.  These series of cards would include the 654x, 655x, 656x series of digital cards.  You can also look at our newest addition to the site, www.ni.com/hsdio.
Kenn North
(4,105 Views)
