Digital I/O
When I set an FPGA I/O pin high, the voltage goes high then decays
Using the Front Panel of my LabVIEW FPGA program, I change an FPGA I/O pin from low to high.  I look at the signal on a scope and find that the output momentarily goes high and then decays.  I can't figure out why its not staying high.  The block diagram below.
Software Version: LabVIEW FPGA Module 2016
Hardware: NI PXIe-7020R
(3,182 Views)
Accepted by SE1W
Is your scope input set to AC coupling? That might explain the behaviour you see.
Not sure about the code since I do not do FPGA.
-AK2DM
(3,160 Views)
