Digital I/O
Writing to two output channels simultaneously crashes nidaqmx (python)
Hello everyone
I'm a new user of NI boards and am a bit lost with a dual stream_writers problem that I can't seem to find a solution to.
I'm trying to use a NI 6229 card with 2 x BNC-2090A (or even a single one) to send periodic simultaneous TTL pulses. One TTL pulse controls a speaker (plays sound waves) the other opens a port for a water release valve.
Independently, these two tasks are easy to do using the
nidaqmx.stream_writers.AnalogSingleChannelWriter()
function and these individual commands:
     water_Writer.write_one_sample(5)
     audio_Writer.write_many_sample(tone)
But when I run them in series (i.e. without closing the first one), I get this error when the second task tries to write:
DaqWriteError: The specified resource is reserved. The operation could not be completed as specified. Task Name: _unnamedTask<4>
I've added a 2nd BNC-2090A breakout board (see ao2 above) and I get the same error. I do have a 2nd 6229 card - but! my computer doesn't have any more slots to insert it into.
Should I not be using the stream-writers function to write TTL output?
Any advice is much appreciate! As I said, I'm quite new at NI + python configuration and a bit lost.
Thanks so much,
Catalin
Here's the entirety of my code, including a function that converts frequency values to oscillations playable via TTL pulse:
#################### HYBRID RUN ########################
def make_tone(f, amp, duration):
   fs = 200000 # 200kHz (Sample Rate)
   T = 1/f
   Ts = 1/fs
   x = np.arange(int(fs*duration))
   y = [ amp*np.sin(2*np.pi*f * (i/fs)) for i in x]
   y_new = np.tile(y,1)
   return y_new
import nidaqmx
# Initialize speaker task;
audio_Task = nidaqmx.Task()
audio_Task.ao_channels.add_ao_voltage_chan('Dev3/ao0')
audio_Task.timing.cfg_samp_clk_timing(rate = 200000,
           sample_mode=nidaqmx.constants.AcquisitionType.CONTINUOUS)
audio_Writer = nidaqmx.stream_writers.AnalogSingleChannelWriter(audio_Task.out_stream,
auto_start=True)
# Initialize water task
water_Task = nidaqmx.Task()
water_Task.ao_channels.add_ao_voltage_chan('Dev3/ao2')
water_Task.timing.cfg_samp_clk_timing(rate = 200000,
water_Writer = nidaqmx.stream_writers.AnalogSingleChannelWriter(water_Task.out_stream,
                                                 auto_start=True)
# realtime streaming with callback
amp = 0.003 # tone amplitude in ?
duration = 0.1 # tone duration in seconds;
ctr=0
freq = 1000
tone = make_tone(freq, amp, duration)
duration = 50000 # time in 100000Hz time base (?)
for k in range(25):
    for p in range(duration):
water_Task.stop()
water_Task.close()
audio_Task.stop()
audio_Task.close()
(2,384 Views)
No.  TTL pulses != sound waves.  However the code is more correct than the description -- you've correctly used an analog output task to generate your sound waveform.
You get errors b/c the 2 tasks are contending for the same hardware resource -- access to the D/A converter.  You can resolve this by using a Digital output task to generate a TTL signal to control the water release valve.  Note: the DAQ device won't source enough current to operate a valve directly, you need the low-current TTL logic signal to drive something capable of sourcing more current.  This might be your valve controller, it could be a simple low-current-demand relay.
-Kevin P
(2,369 Views)
Accepted by catubc1
Oh, great, thanks so much for the quick reply. So
1.  I can't really use 2 streamwriters to output to the same analog channel.
2. Re: "Digital output task to generate a TTL signal to control the water release valve." I can handle the pull up to 5V (probably through an arduino or teensy), butI don't understand how to do create the "digital" output.  Should I initialize the analog port (ao2 in my case) as a digital output channel?  How do I do that exactly?  There are no "digital" channels on the BNC 2090A as far as I can see...
Thanks so much.
(2,335 Views)
The BNC 2090A has spring terminals for digital i/o.  See pages 2-6 & 2-7 in the manual.
-Kevin P
(2,325 Views)
