03-30-2017 02:03 PM
Hi
After reading some technical binder docs I give up.
I let you some information that hoppe can help you.
Best
cpalka
04-07-2017 08:54 AM
From other commenters here it sounds like the communication protocol is MODBUS. There's some LabVIEW MODBUS VIs that can be found here: http://www.ni.com/example/29756/en/
There's also some general information on using the MODBUS protocol and getting started on this page: http://www.ni.com/white-paper/52204/en/
R Dahlman
03-09-2018 05:39 AM
Did anybody have success in talking to an BINDER chamber over Modbus?
I have got the "Binder Interface Technical spec 10-2017" (PDF), but I would like to have an example hot to control and monitor chamber.
Could anybody give an example vi, please?
Thanks and BR
EW
03-09-2018 06:10 AM
I had some success using this methods (see attached files)
03-12-2018 03:07 PM
It seems some users on this forum have had success by reaching out to Binder so I would definitely recommend you do that as well. Also, this forum thread is older and if you are looking to see if anyone on the NI forums has any helpful info I would recommend you create a new thread for the best chance at traffic.
Aaron F.
04-20-2018 07:01 AM
Hi all,
Use this Vi this one worked for me.
Try once using port number 10001 and instrument ip Address.
Follow the user manual for the instrument which has the commands for different functions.
Rakesh
04-20-2018 07:02 AM - edited 04-20-2018 07:03 AM
04-20-2018 07:55 AM
Here my C# class for working with the oven.
Hope it helps
