Digital I/O
can DAQ 6008 control degree of servo motor ?
Hi, I'm new using DAQ and LabVIEW. I've project to control degree of servo motor. can device NI-DAQ6008 control it? I ever used pwm example but I had some error before the program running it.
example motor servo which I want control.
thank's
(6,498 Views)
What error? The 6008 is a very poor choice for pwm as has been discussed numerous times. It only has software timed digital output which you can only output a single value at a time and which will be subject to a great deal of jitter running on Windows.
(6,487 Views)
error task on DAQ is not correct with data, data pwm write 100 in second and DAQ only 1 task. I'm confuse what should I do, or any solution for control servo with DAQ 6008 without pwm?
(6,475 Views)
Hello NMaolana
This is another thread that actually talks the same issue https://forums.ni.com/t5/Multifunction-DAQ/usb-6008-dc-stepper-servo-motor/td-p/2320144  and in there you can see that you can't do a proper control for a servo due to the jitter given the fact that this device only has software timed outputs. If you would like, read through said thread.
Juan B.
(6,451 Views)
thank's all for give me you're experience Smiley Happy
(6,420 Views)
