Digital I/O
configure digital output regeneration with 6533
Hello!
I want to continuous write a digital signal with the 6533 (PCI-DIO-32HS). This digital signal is generate from a finite pattern of 0 and 1 read from a txt file. The user could choose the sample rate and if the sequence will repeat continuously or only once.
  • I tried already with the “Write Property Node” in a while loop with a write function, but I can´t achieve it…The combination of this node with the DAQmx functions: write, start task, etc. that I did is not working.
Which functions should I use (write, start task, node, etc.) and in which order?
Which functions have to be in the while loop?
How should I configure the Write Property Node?
  • I tried also with the continuous sample mode from the DAQmx Timing and a continuous signal is generated. But how can I control to stop the task?
Because with this option I use the DAQmx Wait until done and I have this error -200560
Which option is better or should I do another?
Thank you!
(5,260 Views)
Hi Taurocio,
I would recommend to watch this example, I attached.
Do not hesitate if you have any further questions.
best regards
Richard
(5,190 Views)
Hi Richard,
thank you for your answer.
But I have a problem, because I have labview 2010 and I can't open the file.
Can you maybe "Save for Previous Version" and send to me again?
best regards,
Rocío
(5,182 Views)
