Hello Manliff,
I see that you are using our cDAQ-9401 to program a variable duty cycle pulse train, is this what you mean by "variable timed digital pulse"? I have included a link to an example that you can reference:
NI-DAQmx: Software-Timed Variable Duty Cycle Pulse Train Using Analog OutputIf you are using the DAQ Assistant, much of the configuration is done for you when you select the differnent settings. If you want greater control over the signals you are generating/acquiring, work with the low level VIs. Take a look at the shipping examples to start developing your application. In LabVIEW select Find Example, this opens NI Example Finder. In the Browse tab, Hardware Input and Output>>DAQmx>>Generating Digital Pulses
Addressing the errors you are getting, I need more information:
- what is the error code?
- what were you doing when you got the error?
With regards to your other question, it is possible, and I think someone has already replied to that thread.
Sandra T.
Applications Engineer | National Instuments
