Digital I/O
continuous digital output using USB-6211
I am trying to use the LV example "Cont write dig port - Int clk.vi" to generate a pattern.
But I keep getting the -200077 error about the sample clock. The pop-up error message suggests
using "on demand", but there's no such choice with the DAQmx.
Any hint?  Thanks.
(6,105 Views)
can you post your vi...if you did it in daq express, you can double click the icon on the block diagram and make that choice or change the clock sample mode to finite
(6,100 Views)
(6,093 Views)
I don't think the hardware on the 6211 can support that generation mode.
If you look in Example finder with that example selected, down on the lower left it shows what hardware the example supports, typically the 63xx series cards are shown.
-AK2DM
(6,081 Views)
Accepted by tim_wen
This is correct. The USB-6211 does not have a digital timebase - only analogue. That is why the X series (63xx) cards are only supported for this example.
(6,073 Views)
