Digital I/O
digital I/O output port state
I want to write individual bits on a port using a 6503 DI/O board. Rather than having 8 tasks, I would like to create 1 task and mask the bits to write. To do this I need to get the current state of the port without reconfiguring. Is there a way to read the current state of an output port?
It looks to me like I will either need a seperate task for each bit or keep track of the state each time I write the port.
(3,418 Views)
Thank you for posting to the NI forums.  Unfortunately, you can’t read from a digital output line without first stopping the task, and then creating a digital input task.  Instead, as you mentioned in your post, I would recommend just keeping track of your digital output lines using software.  You can easily create a multi-channel digital output task by entering the physical channel string in the following format: “Dev1/port0/line0:7”.
I hope this helps.  Please post back if you have further questions.
Ed W.
(3,397 Views)
