Digital I/O
digital input
I am running windows xp, Labview student edition 8 and NI-DQmx 8.0. I am using USB6009 to acquire digitized signal from microcontroller PIC16F877 after A/D conversion.
The analog input to microcontroller is a sinewave and the 8 bit digitized signal is fed to input of USB6009 digital line.
I want to know how can I display the 8 bit digital signal to be sinewave again using Labview and USB6009.
1. Am I correct to connect the digital signal to the input digital line?
2. How to configure DAQ Assistant in thi case?
3. Why can't I connect the Waveform Graph to the output of DAQ Assistant to display the sinewave? How to solve this problem?
(3,499 Views)
This post is currently being discussed here.
Matt Anderson
Hardware Services Marketing Manager
(3,468 Views)
