Digital I/O
digital output in scan mode while measuring the voltage
I'm new to here, hopefully some one could give a hand. Thanks.
I have cDAQ platform (NI9178) with NI9403 & NI9222 modules. I need 6 lines of NI9403 as output for a scanner address (from 0 to 63 continuesly scan). Using one channel of NI9222 to measure the scanner voltage output.
The scanner max speed is 45kHz.
Please Help!!!
Thanks so much!
(5,453 Views)
Hi Tscuw,
Would you be able to provide more information? What specifically is your question? If this is a "getting started" question, I recommend utilizing the NI example finder to find base code to start working off of.
Kristen M
Automated Test Product Marketing Engineer
(5,425 Views)
Hi Kirsten,
I'm going to try to explain as detail as possible.
I have a ZOC33 scanner that measures 64 points of pressure (in voltage form). Address, from 0 to 63 should be sent to the scanner one at a time so that the scanner's multiplexer will switch to the proper pressure point.
I use 6 lines of NI 9403 outputs as address control while one channel of NI 9222 continuously collecting data.
In Create Channel vi, I select "one channel for each line" mode. A 2D array (6x64 size) is made to write them in Write vi (2D Boolean mode). I hope it will let the digital outputs continue cycle in hardware timing mode from 0 to 63. I just can't configure it right.
I kHz of digital scan rate was used.
Thank you very much!
(5,407 Views)
Attach your code or an image of the block diagram.
I'm not sure that a continuous scan will do you any good. The analog read will be asynchronous to the digital write.
(5,402 Views)
