Digital I/O
toggling digital output with analog input value
A totally new Labview DAQ system user here.
I have this project where i use USB 6002 to read analog input signal and convert the increasing voltage values to distance.
I was successful at this point.
My next step is to trigger/toggle my digital output with respect to the distance interval.
How ever, the digital output reacts only at the first interval.
Attached is the simple program i made.
(5,184 Views)
Please avoid using Express VIs, you can find example VIs on using the low level VIs for data acquisition in LabVIEW example finder.
You are also running a greedy loop which executes the code as fast as it can, please use a time delay in the loop.
If your DO is not responding as expected you may have to take a re-look onto your algorithm.
(5,130 Views)
