Digital I/O
digital tester with 2 PCI 6229 cards.
I build a digital tester using 2x a PCI 6229 card, controlled by a VB.Net program. Now it seems that the readTask (using readMultiSamplePortUInt32()) can not read more then 1,000 samples per run. It does not matter if I specify in the software that I want to read for instance 10,000 times. Is there a limit on the no. of samples for this configuration?
Who can help me out?
Regards!
Eric
(3,313 Views)
Hello Eric:
I'd like to know how many channels are you reading?
(3,256 Views)
