Digital I/O
dio24
when I run the test panel on Measurement & Automation explorer for PC-DIO-24, I get the following mesage "The device is not responding to the selected base addres" but only when I conect the SC-2060
(3,508 Views)
This error actually is related to the OS you are using. The OS, for some reason, is giving out this message. Things you can try is to place the card, if possible, into another PC (or change the slot of the card in the current PC) and see if you are getting the same error when you connect the SC 2060 to it - also, make sure the accessory for the card is set to 2060 in MAX. If this does not work, then you can connect another 2060, if available, or any other accessory, and see if you are getting the same error. If so, then it could well be that the card needs to be sent for repair - otherwise, the SC 2060 is malfunctioning.
RamziH.
(3,508 Views)
