Digital I/O
for daqcard1200, which line from DIO port C is the handshaking line?
I want to use my dacqcard 1200 to write digital data, as i ve seen in the documentation, i need to supply external signal for handshaking. i d like to know which line from port C, i should connect to this external signal for handshaking.
thanks
(3,113 Views)
Greetings,
The manual for the DAQCard-1200 has very good information concerning the use of Port C for handshaking. Page 3-17 has a table that lists the signal assignments and page 3-18 has a table with detailed descriptions of these signals. If you do not have this manual, it is available below:
DAQCard-1200 User Manual
Furthermore, below is a link to a KnowledgeBase that provides more information concerning handshaking with the DAQCard-1200:
How Do I Perform Handshaking with an 8255-Based Digital I/O Board (Lab/1200, DIO Boards)?
Good luck with your application.
Spencer S.
(3,113 Views)
