Digital I/O
hardware timed digital input with usb and windows
I have a 16 bit data bus I would like to read into a windows laptop. There is a data strobe to tell me when to read the data I want. The strobe will stay high for 1 word period at 10Mbit/sec. (about 1 micro-second) The data rate is much lower than the bus speed. I looked into the usb-6501 but it doesn't support hardware timing and polling won't work at that speed. Is there a usb device that will do this? perhaps a pc card? firewire?
please don't send me to the device selection pages. I have looked and I couldn't find what I think I want.
Charlie
(3,849 Views)
No USB above 1Mhz I believe but there are PCI and PCIe that go up to 100 MHz. Since you said you went through the product pages, what about those did not meet your needs (other than USB)
(3,846 Views)
While the data bus runs about 1 MHz, the actual data I am trying to capture is more like 40 words at 500Hz, or 20k words/sec. (16 bit data bus.)
I really want to use a laptop for the data collection, and most laptops don't have slots for PCI or PCIe cards.
Thanks!
Charlie
(3,814 Views)
Accepted by topic author fred the butcher
Hi Charlie,
The max aggregate sampling rate for USB form factors is 1MS/s or 1.25MS/s for a single channel. The USB-6251 takes in a 16-bit input. For higher sampling rates, you willl need to use a PCI or PXI form factor.
Rohan B
(3,805 Views)
Thanks!
This looks very promising.
Charlie
(3,796 Views)
