@jim.b wrote:
How do you wire up these VIs to create a digital input acquisition which
starts on one of the digital lines going high and stops when that line goes low?
For example, how do you sequence (on the block diagram) the DAQmx Trigger, DAQmx Read, and DAQmx Timing VIs ?
Dear Serges L.
Great work - Your block diagram is very clean and well laid out.
It looks very promising. Did you just create this or have you had it awhile ?
Listen, I'm very curious about the "DAQmx Trigger" VI block around the center of the block diagram:
it doesn't look like anything on the DAQmx palettes that I've seen.
The only VI I've seen on the DAQmx palette is the "DAQmx Start Trigger" VI and it does not have the same inputs/outputs that yours does.
Could you elaborate a little ?
