I 'am using the NI6534 card with a 32 bits inputs interface. I use the NI cable with one meter long.
1° question:
On the NI6534 card i see overshoot and undershoot, the signal is always above 2V and below 0.8V but you have diode on the card to eliminate this effect, why overshoot are still alive.
2° question
When i have the pattern 000000-FFFFFF-0000000-FFFFFFF...., i get errors in the transmission ?
The setup is greater than 6 ns and the hold time greater as 4 ns
best regards
