Digital I/O
how to generate 10KHz software clock for NI USB 6501
I am trying to use NI6501 to send out and read in digital signal with rate about 10KHz. But since there is no internal clock for NI USB6501, I guess I have to use some kind of software clock or timing. This is something new for me and really need some help from you guys. Thank you in advance.
Alan
(4,502 Views)
Alan,
The digital I/O of the USB-6501 is software timed. So the update rate will be dependent on a couple of things.  First, the speed of your PC, and how fast it will execute the piece of code that reads/writes to your digital ports.  Secondly, the USB bus could be the bottleneck.  Unfortunately, I don't think you are going to be able to achieve update rates of 10kHz with the USB-6501, or any other USB device for that matter.  About 1kHz update rates is the best you could expect.  This is because full speed (2.0) USB communication takes about 1 millisecond.
-Alan A.
(4,495 Views)
Hi, Alan. A.
Many thanks for the tips. But I always heard that USB could work up to the rate something like 12Mb/s (or even 480Mb/s!). Is this rate different from the bus rate (1kHz as you mentioned)? Confused. 🙂
(4,494 Views)
Alan,
You are correct that full speed USB has a transfer rate of 12Mbits/sec.  This is a different rate than the rate at which we can send commands to/from a USB device.  Here is a snippet of another post explaining this:   "The full speed interface has a frame size of 1ms, the root hub transmits a packet every 1.0 ms and this is the minimum time that you can read/write from/to USB device".
I hope this helps to clarify.
-Alan A.
(4,480 Views)
You are genius! That's pretty clear for me now. It looks USB port is not a good choice. 😞 Do you have any suggestion to realize the 10Kb/s digital IO with some ports of laptop? Thanks a lot.
(4,479 Views)
Hi Alan,
You might want to check out the NI DAQCard-6533.  It is in the PCMCIA form factor, and it should be able to meet your needs.  Hope this helps:)
-Alan A.
(4,472 Views)
A. A.
Thank you very much.
A.
(4,468 Views)
