Digital I/O
how to generate digital output of variable duty cycle and clock source being counter?
thank u WanL for ur reply.
u described abt varying duty cycle without using counter by regenerating pulses in a loop. but in this case i also want to vary frequency of the two digital pulse trains.
waiting for ur response..
Message 11 of 15
(3,700 Views)
Your sampling rate is fixed by the sample clock. If you want your output frequency to change, you can vary the number of samples per period of the waveform that you generate on each iteration of the loop.
Wan L
Applications Engineer
http://www.ni.com/support
Message 12 of 15
(3,691 Views)
Accepted by dg7318
i got this code modified
Message 13 of 15
(3,622 Views)
Accepted by dg7318
also download this
Message 14 of 15
(3,621 Views)
thank u wanLfor ur help.
Message 15 of 15
(3,618 Views)
