Digital I/O
how to generate digital output of variable duty cycle and clock source being counter?
thank u WanL for ur reply.
u described abt varying duty cycle without using counter by regenerating pulses in a loop. but in this case i also want to vary frequency of the two digital pulse trains.
waiting for ur response..
Message 11 of 15
(3,698 Views)
Your sampling rate is fixed by the sample clock. If you want your output frequency to change, you can vary the number of samples per period of the waveform that you generate on each iteration of the loop.
Wan L
http://www.ni.com/support
Message 12 of 15
(3,689 Views)
Accepted by topic author dg7318
i got this code modified
Message 13 of 15
(3,620 Views)
also download this
Message 14 of 15
(3,619 Views)
thank u wanLfor ur help.
Message 15 of 15
(3,616 Views)
