Digital I/O
how to generate pulse on digital i/o line ? usb 6211 labview 8.5
i want to generate a 5ms pulse on one of the digital ouput lines which will be further used for delaying DAQ acquisition.
thanks
(4,118 Views)
Accepted by mpsarma1
You will need to use counters to generate a digital pulse. I would ask you to take a look at the examples that are shipped with the DAQmx driver (In LabVIEW, goto Help -> Find Examples).  Search for pulse and select Generate Dig Pulse.vi. If you have any questions, post back!
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,113 Views)
Thanks but i am sorry i have not mentioned that one counter is already in use for generating a sequence of pulses
in a process while the other counter is also engaged in counting a period by two edge measurement and the couners are busy.
So i need a method to generate an output pulse from digital output line only with out involving counters.
any help?
thanks once again
(4,100 Views)
Well, you could use a sequence structure and have two digital outputs for on and off and put a wait in between there, like we usually do when programming FPGA. But, I don't think it's going to work as well especially since the entire sequence will be software-timed. I would recommend a new counter card.
Adnan Zafar
(4,092 Views)
