Digital I/O
how to get digital signl into labVIEW
hi,i have 1 problem that is how to get digital signal into LabVIEW without using DAQ card
(5,336 Views)
Accepted by yh87
There are many ways you could load a digital waveform from file:
readFromMeasurementFile.PNG The Read From Measurement File Express VI
or
readWaveformFromFile.PNGThe Read Wavefrom from File VI
or
simulateArbitrarySignal.PNGThe Simulate Arbitrary Signal Express VI- use the Define Signal > Load Data button.
If this doesn't help, could you provide more data, also why can you not use a DAQ card?
(5,329 Views)
i will try the solution given
(5,323 Views)
The above suggestions may not help, if they don't, please give further detail into what you are trying to do.
(5,322 Views)
i need to do 1 programme using labVIEW the output is an EPOS control robot and the input is EMG wave but i also not sure how to get EMG wave into computer and our group choose not to use DAQ card because it istoo expensive
(5,289 Views)
Not sure if it's the same thing but there is a driver for a Maxon EPOS motion controller.
If you need to acquire an external signal and if by EMG you mean electromyogram, you are either going to have to purchase a DAQ device or design and build one yourself.An EMG is not even close to a digital signal.
Message Edited by Dennis Knutson on 07-26-2009 09:33 PM
(5,285 Views)
