Digital I/O
i have a pci6527 card and a scb-100 module. I don't know how put a 24v signal on a output channel. pls help me, i'm a newbies
I don't understand what the manual said, about des switch for thermocouple and i just want to have a 24V signal on 8 outputs channel and 24v on 6 input channels.
(3,400 Views)
Hello;
The board you are referring to, as well as most NI DAQ devices, have an input/output range of -10V to 10V. That means you can't neither generate nor read 24V signals, without some sort of signal conditioning to attenuate its range so it falls within the -10V/10V.
You can get a full set of specs fot that DAQ device on its Users Manual that you can download from www.ni.com.
Regards
Filipe A.
(3,400 Views)
