11-06-2013 02:49 AM
Hi Melanie,
yes the hardware name is correct .. I get this error see attached picture please .. i tried to re-assign all FPGA I/O methods and nodes .. but the error still the same ! any idea on how to solve it ?
thanks
Mustafa
11-08-2013 11:09 AM
Hi Mustafa,
since i am not sure what is the cause of the problem now, could you please try to migrate the sample I2C Communication for sbRIO project to your hardware? The only thing I could imagine at the moment is that the migration was not correct because I do not have your hardware here. I found a link, that describes how to migrate a RIO project to other hardware. It is a step by step go through. Please try this. You can find the link here:
Moving Examples to Another FPGA Target - National Instruments
http://www.ni.com/white-paper/5075/en
Melanie
11-11-2013 03:46 AM
Dear Melanie
i do it step by step but i got this error in attached pic 😞 any advice ?
thanks for your cooperation
Mustafa
11-11-2013 03:54 AM
Hi Mustafa,
have you checked the properties of the queues in the project? Refer to the original example project for information and sample properties.
If this does not fix the proble please add screenshots from the properties dialog of both queues.
Melanie
11-11-2013 04:41 AM
Hi Melanie
they are the same for both read and write and both projects coz i just copied it from the original target
Mustafa
11-11-2013 05:33 AM
Hi Mustafa,
since you needed to transfer the project to another hardware, you have to modify the ports that are defined in the project.
In the project file is the folder IO under the FPGA target. Please assign the data and clock ports to your hardwares clock and data ports. Connector 0 DIO 0 should be the clock, Connector 0 DIO 1 the data and so on for the second port.
Melanie
11-11-2013 06:15 AM
Hi Melanie,
i did and there still one problem after i re-assigned the Read/Write FIFOs
Mustafa
11-11-2013 06:16 AM
Hi Melanie,
Mustafa
11-11-2013 07:34 AM
Hi Mustafa,
I think this is a code optimization related issue of the compiler. The loop that contains the Read node has to be executed for min. one time to be not deleted from the compiler. So make sure, the parameter that defines the loop iteration amount is not 0.
Melanie
12-30-2013 11:19 PM
Hi All,
We have a cost effective solution for I2C protocol decode , Prodigy Technovations is a 5+ year’s old Product Engineering Company, Prodigy Technovations can support you with wide variety of protocol analysis and compliance software for validating low speed and high serial Interface.
Currently @Prodigy we are enabling compliance suit development activity for high speed serial interfaces like I2C, eMMC,SD,I2S,Gigabit Ehternet, USB2.0/3.0, SPI and many more .
For more details on the products , please refer the link below.
Looking forward for an favorable and early response
Yours sincerely,
Prodigytechnovation
contact@prodigytechno.com
