Digital I/O
ividmm peak vs. peak-to-peak
How can I set by IVI on my DMM to measure peak or peak-to-peak AC voltage?
thanks Michal
(3,525 Views)
First, you posted to the Digital I/O board. You should have posted to the Instrument Control board to get a question answered about an IVI instrument.
The IVI DMM class only has AC volts which will be the rms value. You can calculate the peak or peak-to-peak from that if your waveform is a regular shape (sine/square/triangle). If the instrument has a peak or peak-to-peak measurement setting, then you can use the instrument specific command though you will lose some of the benefits of IVI. Lastly, if the instrument supports the mult-point extension, you can do a capture of the waveform and analyze that in your code.
(3,521 Views)
First, i noticed wrong placed of my question too late and i don't know how to replace it right board.
Thank you very much for your answear. That's what i wanted to know.
Thanks Michal
(3,515 Views)
