Digital I/O
multiple digital pulse trains with daqmx
Hello guys,
I am new to this forum and to Labview. I use Labview 7.1 with DAQmx 4.5 and the Mio 6251 card.
My problem ist that I want to generate five multiple digital pulse (TTL) trains to trigger some devices, e.g. I have a 2 cameras, flashlamp, image intensifier and an injection device. For all these devices I need triggers that should be referenced to one of the five triggers and they should be flexible in high-lowtime etc. The accuracy should be 1 mys. The national instruments guys where we have bought the hardware, told me that this is possible to do.
In the attached vi I have tried to do that by using a property node. Can anybody please explain how I can solve my problem?
Thank you very much in advance
Sven
(2,967 Views)
I have to say that I wanted to do that by using one counter where all triggers (PFI channels) from the property node are referenced to that counter. If I change specifically high-lowtimes and initial delay for each seperate PFI Channel at the property node nothing hapended. Can anybody explain why. I think that must be possible cause you can choose high-lowtime and initial delay for each channel seperately. Can anybody explain what I am doing wrong?
I have attached the new vi. It should be more clearly now.
Thanks in advance
Sven
(2,961 Views)
