Digital I/O
mx base
I'm trying to install the daq mx base driver to run a USB-6501.  If I access the "Measurement and Automation Explorer" it shows I have the NI-Daqmx base 3.2 software.  Under Program files/National Instruments/ I also see a "NI-DAQmx base 3.2 folder".  However, I don't see any of the mxbase vi's to pull up from the functions menu on my block diagram (only the daq mx ones).  Is there something I'm doing wrong?
Message 1 of 9
(5,107 Views)
What version of LabVIEW are you using?   (I don't no witch which 😉
Message 2 of 9
(5,099 Views)
LabView for Windows, version 7.0.
Message 3 of 9
(5,095 Views)
For some reason, I thought I needed mx base to control the USB-6501.  However, looking at the device list again, it looks like I should be able to use mx after all?
Message 4 of 9
(5,093 Views)
BSW,
DAQmx Base 3.2 does not support LabVIEW 7.0.  Typically DAQmx Base is used for MAC, where DAQmx is used with Windows.
h_baker
Message 5 of 9
(5,080 Views)
I wouldn't doubt it, but the driver list shows NI-Daq base 3.2 available for Windows:
NI-DAQmx Base 3.2 Windows CE/Mobile 5/Vista x64/Vista x86/XP Hardware Driver
Message 6 of 9
(5,075 Views)
Accepted by BSW
It is available for Windows to help transition code across platforms.  It is possible to code with DAQmx Base in Windows; however, it is not the most common practice due to its limited palette compared to DAQmx.
h_baker
Message 7 of 9
(5,056 Views)
Excellent.  I primarily use LabView for OSX.  Probably the reason for the difficulty getting things to work on Windows!
Message 8 of 9
(5,039 Views)
BSW,
If you want to continue to program in DAQmx Base to go between Windows and Mac, then you can use NI-DAQmx Base 2.0 for Windows.  It supports LabVIEW 7.0 and the USB 6501
h_baker
Message 9 of 9
(5,009 Views)
